Re: Wide Open a Problem?
As I pointed out the OB are detuned versions of the high output auto engines. One reason they do this is to allow the marine engines to run at heavy loads and WOT. You give me a Suzuki or Yamaha or Honda 115hp and some money (quite a bit) and I will give you a 170hp outboard that probably will scare you but probably WON'T want to run at max rpm (~7500-8000) all day under a heavy load. Time will tell but I'm betting that the marine 4-strokes will hold up pretty well for a long time if they are run hard. Any engine's internals will wear longer at lower stresses, but how many of these engines 2 or 4 stroke wear out I wonder? Most of them get killed by overheating, corrosion, water intrusion, or some other non wear related problem.<br /><br />LubeDude I'm going to stick my neck out and say that if you took my car engine, put in a huge radiator, changed the cams and intake to reduce the hp from 170 to 115 at 6500 rpms and put it under a load that limited it to 6000 rpm in 5th gear it would hum along quite well for a long time. As it is, I travel the interstate at 4500-5000 rpm right now.
