Hello all,
I am having the Wierdest Etec issue. First off I have a 2008 40hp Evinrude Etec with Tiller. Ive taken it out about 5-6 times so far and the other day I had a problem where when I shut down the motor via the red stop switch (not the key) there was a wierd continuous humming noise after the motor was off and if I tried to restart the motor it would not start. The starter would kick in but the motor wouldnt start. So, I then turned the key itself off and back on again and this somehow reset the motor and the humm went away and the motor started up perfectly like usual. This problem has happened only twice so far out of many other shut downs with the red stop switch on the tiller handle that worked fine.
Any ideas what could be causing this? The fact that turning off the key and turning it back on again fixes the problem makes me think this is a problem with the onboard computer???
Thanks for the help,
Mike Krivsky
Wisconsin
Mike Krivsky
Wisconsin
