Wilcox Crittenden Steering Wheel ?
ghamby
I have sought but not found. Any sources out there for pics and parts on
a WC cable steering wheel, '50s vintage.
Please advise, GH.
Ned L
Re: Wilcox Crittenden Steering Wheel ?
They come up on Ebay. What do you need for parts, there isn't much involved in them (the wheel, decorative wheel hub cover, shaft, pulley, 2 nuts & washers, & the through dash casting). The only source I know of that still carries some of the 'traditional' cable steering parts is Glenwood Marine (check their web site).
ghamby
Thanks for the reply,
In particular, I need a new shaft (insert tasteless comment here) or the
specifications so I can get a new one machined locally. The existing one
was so corroded that it had to be cut out of the mounting. I can piece it
back together to get the measurements but a drawing or replacement part
would be helpful. A new set of teflon bushings would also be nice. they are
of an odd size. McMaster-Carr doesn't carry them. Two parts need re-plating.
This I can handle through a re-plating shop. I am open to recommendations
for re-platers in the Mid-Atlantic region.
The wheel itself is hard rubber over a steel frame. It needs a re-paint.
Suggestions appreciated. Thanks, GH
ghamby
