Re: Wild RPM's on a 3.0 Merc...
Check connection to the tacho are clean and tight... Check battery voltage... Check wires on the coil are clean and tight....Check all grounds are clean and tight.... Check all pins in the harness connector are clean and making good contact........
Chris...........
