Will 200 HPDI Lower Fit 200 ETLN?
Jprevat
I have a 200 ETLN that needs a new lower due to freeze damage and water intrusion that was left unchecked by the previous owner as he had it sitting outside. I have a chance at a 200 HPDI lower for less than $500 and cant really find any way to cross reference the two to see if this would work.
So I am hoping someone here can help me out. I am new to yamahas so feel free to call me out on any mistakes or assumptions I make. Thank yall ahead of time for your help.
99yam40
if the part numbers are the same they should fit.
make sure they are the same gear ratio and length
Jprevat
I was having a little trouble finding part numbers for the complete lowers. I did get back with the guy and he says that the model listed on the title is Z200TL.
Where could I go to look up part numbers? Thank you for your help.
Jprevat
Thank you for the resource. I did a little digging and they do indeed have different part numbers so I tried a non traditional route. I asked SEI which of their lowers would fit each of those models and they gave me the same part # for both. I think Im going to give it a shot and see how it goes. The guy said if it didnt bolt up perfectly then he would take it back so I figure why not.
