Re: will 60hp 3cyl evenrude vro carbs fit?
Ok, took the boat out today to field test Walleyehed's suggested setup changes with motor height and got what i was looking for (30mph with gps as 6000rpm on 13 in prop, good hole shot) turned motor off after about a 1 mile run at full throttle and it wouldn't start again. I know that I have great compression, new coils, new power pack, and new trigger, also have rebuilt carbs and link and sync'd (see performance above) however, when this motor runs a while it won't start again. We are fairly sure that the stator is breaking down when it gets hot, so tomorrow will run it on muffs until it gets hot and do stator output tests and pack outputs. I really hope that this is what my problem is, as I have basically replaced everything else (it has all failed within the last year anyways) I just really want this motor to work right for awhile so I can concentrate on fishing instead of working on the boat.
