Will a 1979 250hp cable shift outdrive interchange with 1985 5.7L cable shift outdrive
Smilin_Bob
I have a 1985 OMC 5.7L with a junk outdrive and an opportunity to acquire a 1979 OMC 250hp cable shift outdrive. The upper gear ratios are the same. will they interchange?
Redrig
My understanding is no.....the hydro shift cable from 79 can not be swapped around with the later mechanical shift cables.
