Re: Will a 77 t&t fit my 73
It will fit, but you will need the wiring harness, tilt trim switch and relay box to go with it. You can use an on off on toggle switch if you don't have the origional and you can wire in starter relays if the relay box is not included, but if you can get everything factory you are better off.
