Re: Will a Trim & Tilt unit for
There is no appreciable difference between any Mercury, mariner, or Force single ram trim system. If you engine brackets accept a single ram system from one then it will also accept a single ram from any other. The internal designs of pumps, manifolds, and trim limit spools changed over time but the ram and mounting remained the same. Make sure to install anode and wire strap. You can set horsepower from one engine to another with the trim spool spring. or just disable the trim spool entirely and the system will lift any horsepower to any angle at any time. With trim limit disabled you'll bend or break something before the engine stops lifting.
The early models with round plastic reservoir are not very good design. Unless the price is great then you may want to pass on that style and hold out for a 97-09ish system with the square reservoir base. Much better pump design. and, if you can be picky, go for the two wire motor. It sucks down less juice.
