Re: Will any Jackplate lower my motor?
I have a steel barge and had a welder put on a new 3/4'' steel engine bracket for my Merc 150. He completely messed up and welded the plate 5" higher than he was supposed to. My question is do they make any kind of Jackplate or ANYTHING that will lower the motor instead of raising it?
wow 3/4" STEEL!!!!! its only a 150!!!
I think if it has holes for mounting a standard outboard, most Jack plates wont work.... they fit at normal height, and then GO UP from there..
unless they can be mounted upside down?, certainly not a hydraulic unit.
you could get a fixed jack plate, and probably invert the mounting...
youd be better off all around getting the plate rewelded were it belongs so you have lots of versatility for standard stuff..
but you can get some set back if you go with a jack plate......
any pictures??
bob
