Will Fiberglass Adhere to Metal?
Solittle
I pulled the galvanized fender to my boat trailer off and discovered some heavy rust on the underside. It has eaten through in a couple of places. If I put a layer of glass cloth on the underside will it adhere?
ZmOz
Re: Will Fiberglass Adhere to Metal?
I don't know, but a new fender is only $10-20...
Bass Runner
a better fix is bondo the holes and glue 3/8 rubber sheet to the underside, stops the gravel from knocking the paint off and no more dents. Hope this helps, figerglass is brittle and the rocks will break it.
I'd just replace them as ZmOz said. Cheap, fast and will give years of service.
Solittle
I doubt that I could replace them for $10-20 but will check. If it runs $20-30 that would mean $40-60 for both and I could do the glass for under $15.00. This is a tamdem axle galvanized trailer and the fenders are relatively OK except for a dozen or so relatively small rust holes.<br /><br />Again will fiberglass adhere well to metal?
crazy charlie
You will have to clean the rust to the point where it will adhere.If it is cleaned properly-it will adhere.Charlie
SoLittle<br />Ah, now we know a little more. Might as well do all four at the same time. I checked two sources and fenders for 13-15 inch tires. Price 20-35 dollars and tanden fenders run 30-45 dollars.<br />After cleaning and repairing you might want to brush on a under coating of some type.<br /><br />Just checked under the trailer section of this forum so I'll shud up now and just read and learn myself :)
