Will Ford copper SP wire sub for braided silver?
ba_50
This '57 Johnson 35hp RD19 has silver braided plug wires. I have some ignition wires that says Hypaloncopper conductor. Will any wire work?
This one has a straight end on it and can it be swapped for the 90 degree one? The 35's has the sharp pin that goes into the wire. Not sure about the other one.
I doubt if splicing would las since they get jolted back and forth.
Thanks.
wilde1j
Re: Will Ford copper SP wire sub for braided silver?
Metal conductor required ... no carbon conductors. Standard Packard spark plug wire works fine.
F_R
Thanks.
Silver braided??? You mean like braided on the outside? That sounds like it may have the radio suppression kit on it. A rare bird. Yes, stock wire was a copper core hypalon type.
w2much
You can purchase copper wire by the foot at NAPA, I did.
ba_50
It is twisted inside the insulation.
ba_50
I stuck a copper wire on and got a spark. Thanks.
