will it fit
speed5
hello i was just looking to repower my 90 115 hp evenrude due to a slight problem with a garbage bag my question is when i look up for a replacement power head it comes up from 110 to 140 hp will a 140 hp block fit on a 115 frame or mount in is same place if going to spend money why not just upgrade to more hp. and if so what is the diffrence
Dhadley
Re: will it fit
Any V4 crossflow powerhead from 1979 & up is a direct bolt on replacement. On some early models (79 to mid 80's) there may be a boss or two different but nothing you cant get around.<br /><br />V4 crossflows from 1978 with powerheads from 25" motors will bolt on but the crank has a smaller middle main. Same for any 1978 140.<br /><br />The by-pass coves will vary too but you can always use yours on the new powerhead.<br /><br />Just dont get confused and think a 140 looper will fit.
speed5
Re: will it fit
thank you for the help what is a looper and will it say that when i order it
Dhadley
Re: will it fit
V4 loopers started in 1985 and were 120 and 140 hp. After 1985 no crossflow was rated at 140.<br /><br />What you have (1990 115) is the same as the older 140. If youre going to order one just order that. They were the same from 1990 to 1998.
