Re: Will it Float?
I think you are mostly right Ziggy. The exhaust is not sealed for water. The way it works is to have a riser system significantly higher that the boat water line to prevent intrusion of water into the boat through the exhaust port. The bellows is simply a channel for the exhaust gasses to get away from the transom. In fact, my bellows is full of holes all along its length by design for back pressure relief. The only thing I am sure is not correct is that the flappers stop the water from coming. The water stops completely as a result of the static line being higher than the boat water line. The flappers are for a water surge such as when the wake splashes up against the transom when coming down off plane in a sudden slow down of the boat. The wake causes a surge of water which could, if it hits right, force water up the exhaust system (even more so at very low idle or a stalled engine condition) and into the engine and boat. The flappers will slow or stop most of the water but they do not seal tight. Don S has made a point of this in several other posting as well. Flappers do not and can not stop all water ingression, they just prevent major ingression. That is why flappers are needed even with through hull exhaust as well. If the exhaust outlets are any where near the water line, the back wash from the wake or waves hitting the transome (particularly common in reverse) could let water ingress when the exhaust flow is very low at idle or if the engine stalls.
