will main wire harness work
easygo0
have now twin 1986 200 etxj will same main wire harness work with twin 1997 efi s225txrv have analog gauges dual oil tanks.thanks for any replies
rodbolt
Re: will main wire harness work
yes and no.<br /> can they be adapted to work? yep. is it worth it? nope.<br /> the oil tanks will work but I would reccomend a thorough cleaning and new transfer pumps. a defective pump can trash a new CDI/ECU to the tune af about 1500 dollars. not worth it. the 10 pin main harnes will remain unchanged with the exception of the choke switch, the choke switch will be usless and will no longer do anything, doesnt need to either. the trim and the oil alarm harness's will have to have adapters, the trim indicators wont work. the remote oil tank engine harness will have to have an adapter on the engine end as well I believe.myself I reccomend new trim and oil alarm harness's with updated digital tachs with selectable 2/3 wire trim and hour meters.
