Re: Will my 59 Fatty 50 be to heavy for my 65 14' Bellboy ski boat?
Well, I went over to
www.fiberglassics.com. They don't list Bell Boys later than 1960, but the 14' model was pictured with a 1960 Evinrude 40 hp on the back. I doubt they changed the design all that much in the intervening years, and were probably using the same molds in 1965, but with slight changes for appearance purposes.
You need a short shaft for that boat, as you already know. I thing, though, that it was probably designed for the 40 hp outboard, not the 50. The weight difference between the two is dramatic, while the horsepower difference is not that much.
If the weight of the 50 hp makes the stern sit too low in the water, it will not perform as well with the 50 as it would with the lighter 40 hp.
I'd be willing to bet that the maximum hp rating for your little 14' boat was 40 hp, not 50, and mainly because of the weight.
It's your call, of course.
