weekender1
- Joined
- Apr 12, 2011
- 99
hi all well its about time to get here in the water went to fire up the motor, inline 6 250ci 165hp the motor is a 1973. well it cranks but will not fire even if i put gas down the carb. i pulled 1 of the plugs to check for a spark and it did turn over and seemed like it wanted to run with the plug out and even time i try you can see some smoke comeing out of the prop so i am confused now i did pull the plugs in winter and when i did i wrotw on the wire 1-6 on them from front to back so any ideas would be nice thanks..
