Will not trim up under power
sightsrv
Hey, Please someone knows tell me 2morrows the last day for
a month can take it out again. 2000 stratos 21ss, 2003 merc
225 efi. jack plate..etc..Had a mech take hotfoot out cant use
it due to bad leg. Tilt and trim worked fine the one on the steering
wheel and on the throttle. Trim gauge on dash was perfect also.
Took it out after "fixed" in neutral trims up and down perfect hit
the gas it will not trim up for any reason and the gauge was screwed
up. It worked but not reading right. Took it back spent $180.00
I should not have been charged for. Fixed they say. Today took
it out and its exactly the same. You can trim it up in neutral hit
the gas and the ob trims down by itself. Just called him and he
kinda says not possible, your doing something wrong. He says
never heard of that. PLEASE help if ya can. He wont look at it
till next week be honest he wont be seeing it ever again.:mad:
:confused::grumpy::blue::facepalm:
Its this boat the nitros gone. Try add a link.
http://1drv.ms/1cuHpmY
Dukedog
Re: Will not trim up under power
Only time I've seen that turned out ta be seals in tha trim. Wouldn't hold under throttle.............
