Will this carb fit my motor?
Mirko
These carbs are for sale on ebay. I would like to rebuild my carbs but frankly am a little afraid to do so. If I could buy these, rebuild them and then install them in my motor, Iwould feel more confortable about doing it. I could take my time that way. My motor is a '94 115hp Johnson. V4 crossfire. Model number J115TLERC. The carbs on ebay are from a model E115-TLCIM.<br /><br />Are they interchangeable?<br /><br />I have ordered a parts catalog so hopefully I won't have this problem in the future. I will then have two manuals (OEM and Selco) and a parts catalog and hopefully that will help me get smarter.<br /><br />Sorry to be a pest and thanks in advance for all the help.<br /><br />Mirko
DHPMARINE
Re: Will this carb fit my motor?
Mirko,<br />Just off the top of my head...Your motor has 4 individual carbs?Right?<br />I believe the older motor has 2 two barrel carbs.<br />Sorry but it won't work.<br />rebuilding your 4 carbs is not that hard.I suggest you get the factory manual for this job.<br />Go step by step....and it can be a two day project.Shops do it in less than 3 hours.Remove one carb at a time,rebuild it,and then go to the next one.By the way...float level..invert the carb and make sure float is level with the carb body.<br /> DHPMARINE<br /><br /> DHPMARINE
Dhadley
Yes they will work. The carbs on e-bay are from an 1981 V4 crossflow motor which is basically the same as your V4 crossflow.<br /><br />What is the difference between cleaning those vs yours? I would sure rather clean a set that I know rather than an unknown set that Ive never seen.<br /><br />Good luck!
