Re: Will this LU fit Force 1984 125 hp?
no it did not come off of a 1983 force 125. mostly because A. in 1983 force was still chrysler, and B. it is black with the 2 piece drive shaft. so you are right to think it is off of a later motor. it will fit you motor BUT they did change water pump housings through the years (once) so you might have to grind a little piece out of you lower leg (not a big deal, you can even breake out a chunk with a pair of pliers and a hammar) and as for the gear ratio, looking down from the top of the lower unit you will see 2 numbers 1 saying forward gear, and i forget what the other number says, but that will tell you your gear ratio. or turn the shaft by hand and count the ratio. but this Will fit your motor. just be sure the shaft length is the same.also it apeers to be missinf the exhaust snout
