Put a cover over them?I was thinking along the lines of bulding my next house with solar panels covering the entire roof, but how do i protect it from hail storms?
Would'nt that block out the sunlight?
I have thought about some sort of a mesh, but wanting the house to be aesthetically pleasing at the same time is giving me some thoughts for pause.
One very effective way to save energy is by using sun energy to provide you with hot water.
If you live far enough to the south so your sun collectors don't freeze that is.
During my years in Israel we always had our hot water provided by sun panels on the roof.It is a very simple and very effective way to save energy.
If you are interested in opinions about these water heaters,google :"dood shemesh"
My biggest question with the wind turbines is if I should run them in series or parallel. I'm planning on putting in 3 small ones if I do this project... and by small I mean 2 to 2 and a half foot prop. diameter with 3 blade props... I'll be glad if I can get even 100 watts out of them.
Ive seen the same thing done but wrapping your copper tubing around you wood stove pipe. The other thing with you guys who live in the hot south why don't you bury a water container in the ground and pump it up through a heat exchanger with a fan to cool your house.One very effective way to save energy is by using sun energy to provide you with hot water.
