76SeaRay
- Joined
- Aug 24, 2017
- 1,071
I am starting the assembly of my 5.7L vortec engine (4 bolt main) but ran across a question on the correct windage tray. I ordered and received an Engine Quest tray with standoff bolts. It has 5 standoff bolts so is intended to bolt at mains 2, 3 and 4 (2 at main 2, 2 at main 3 and 1 at main 4). However, when I have reviewed pictures of stock vortec engines on the internet for rebuilding the engine, it appears that all the pictures show a shorter windage tray with 3 standoff bolts (2 at main 3 and one at main 4). The one I received says it is for Mercruiser 5.0 and 5.7L 1996 so I assume it is correct.
Can anyone verify that the longer tray will fit ok using the 5 bolts? Also, will a stock oil pan (without baffle) work ok with this windage tray? I wonder if it will hit the bottom of the pan at the front.
Thanks.
Thanks.
