rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Installing a Horizontal "Quick" Brand Model 1200 on the front bow of my boat. The question is this....
The Rope essentially will be going thru two decks spaced 5" apart. I"m wondering if this will be ok, and if the lower "deck" opening has to be larger than the upper to avoid and mis-feeds.
I will explain: The windlass is mounted on a fixed hatch surface. The inside of the opening extends down 5", I am using a 1.5" (yes, very thick and sturdy) plywood piece as a Backer for thru bolting the windlass from the top surface, through this thick backer board.
The backer covers a very large area on the underside, I'm not at all worried about strength as the load will be well distributed. However, now I have basically 2 decks to go through. Also I have plenty of drop under the backer board-Verified.
The manufacturer mounting template cut-out (and the matching underside of the Windlass) has an opening of 2 3/8" x 1.75. Its not very large. Then the rope has to drop a 5" void of space, and thru the 1.5" backer board.
Wondering if I just need to ensure this "secondary deck" opening is quite a bit larger then the upper opening. I'm wondering if anyone has done a similar setup, and if there will be any issue with the rope passing through??? Do I need to make a "pipe" or passage between the two openings??
