I have a 2359 trophy 2001, a previous owner must have had this windlass added, per bayliner this boat does not come equipmented with one, the windlass is a Lewmar Sprint 400 I do not know the year, max pull is 400 lbs 12 volts and 150 watts. when I put the battery switch to both and tried to pull the anchor up (10lb anchor) it would not do it, it only had a 25 amp fuse. since then I have added two strings of batteries, two on switch one and two on switch 2 on both it would have four 12 volt batteries, added a 100 amp fuse and new wire, but still having problems, blows fuse. is it time for a new one ?
