Windshield glass replacement
Cptkid570
Ensign
Hi everyone,
1996 Four Winns 240 Horizon. I need to replace the front port side window glass (it was broken out when I bought this boat). It's not an ordinary straight/flat piece of glass, it curves around at the end. I've attached a photo that more shows the starboard side so you can see what I'm talking about (it's the front, not the side glass).
My question: Do you think a glass shop can make this piece of glass eventhough it curves around? Or do I have to buy a replacement piece of glass from the dealer (it's around $350 from the dealer).
I spoke to one auto glass place and they said they couldn't make it. But I don't think they were a glass maker, just an installer.
ziggy
Re: Windshield glass replacement
i've seen a lot of folks getting grieved over getting windshield parts. if the part you need is available, i'd be getting it before it gets obsolete.
cribber
That's a complex piece of curved tempered glass. You'll be hard pressed to find a place that can make it but you never know until you ask around.
erikgreen
A "real" glass shop can make it (most of the auto glass places out in the world only install prefab parts), but the cost will likely be more than the dealer.
Making a custom curve like that will require fabrication of a metal mold, followed by heating of the glass to temp and slumping it into that mold, plus the usual cutting, grinding, polishing.
For a '96 you might try salvage yards, ebay, etc... it's possible that similar boats the same model year or boats from adjacent years used the same windshield.
But if all that fails, buying it from the dealer might be cheapest.
Erik
ezmobee
From what I've seen people have to pay and go through to get a boat windshield or part......spend the $350 and thank your lucky stars it was available!!!
Fu-Inator
I had a similar problem with my bow hatch window. It broke out last fall while I was towing it down the highway (I think a semi-truck kicked up a rock). The class is rectangular with a slight bend and I could not find a place local to make a new one. I could replace it with plastic but that would scratch and yellow over time. After checking with 8-10 glass places, I ended up having to order it from a dealer. Of course I couldn?t just get the window; I had to buy the whole ?hatch? with frame and all.
$350ish total and I installed it myself.
