winky blinky help
thefishingfreak
i got it.<br />how do i use it?<br />engine cold?hot?key on?<br />the good engines stumbling, gotta be fuel pumps.<br />but i want to play with my new toy, winky blinky.<br />any source for the code info also?<br /><br />another question?<br />how to adjust tps? the clymer book dosn't cover that.<br /><br />1990 vx76*250's<br />thanks,<br />mike
rodbolt
Re: winky blinky help
hello<br /> you must dissconect the oil level sensor and plug it in. start the engine and watch the codes flash. will be 1/3 second flashes followed by a 1.7 second pause for the second digit followed by a 5 second pause then it does it again. code 33 will appear at start and warm up then change to code 1 .if your engine is trimmed higher than 2 bars you will get a false code 10.if I can figgure out how I will try to scan some info and send it to one of the moderators so they can post it. I also have all the procedures for TPS setting. did you buy the TPS adjusting harness? and be aware while running with the diagnostic lamp you will have no oil transfer from the remote tank. all the alarms will still be functional.<br /> good luck and keep posting. code 33 is engine warm up.
thefishingfreak
thanks rodbolt,<br />yes i have the harness testor also, and the pocket testor.<br />mike
