hc43
- Joined
- Aug 19, 2014
- 28
Well I have been reading about every resto thread in here I can find and think I am ready to take the plunge into my own. I purchased a 1979 Winner Something. No idea on model I can not find it on the the ownership and the transom tag has gone MIA. From what I can find on the net ( which isn't much) I believe it to be a Marauder. It is dead on 16feet (sorry my keyboard is screwed at the moment I keep getting ? when I hit feet) and has a 78 inch beam. I bough the boat knowing what I was getting myself into as the PO said the transom was ok but upon seeing the drain plug out and feeling the wood inside I knew I was going to have to replace it and at the time I thought the floor and stringers would go with it. When I brought it home and started to tear into it I had all kinds of surprises. The stringers are all hollow fiberglass and it has no foam. Instead it had these plastic bladders which in my case half were full of water. Now at this point I started to take off the rub rail to begin to remove the cap but ran into a small problem. It seems like one of the POs had the cap off but instead of removing it properly he decided it to the easier to use a sawzall or some other type of saw and cut the top off. He also decided it was best to take the cap and pull it over the bottem lip he had created and put about 60 rivets a side to hold the cap to the hull and fiberglass the crap out of the back. So now I have a problem that I would like some advice. Do I try to remove the cap or do I cut the splash well out of the back?. That's where Im at now as the boat is sitting on a homemade dolly in my garage. I have been waiting for warmer weather to do anymore work as the garage is just big enough to fit the boat into. Another question I had is the boat is rated for 95HP from what I see on the net but I bought a 1979 Johnson 100HP. Now to me I think I was a bit ambitious and the motor is to big for my boat as specs state it weights in around 300lbs but would like some adive on what you guys run. I want this to be a family boat as I have a wife and 2 year old child. This will be a slow resto by the way as my wife and I work separate shifts. Now its time for the pics as I am getting very tired and feeling like I am just rambling on.
Under the rub rail.
Some more handy Work. I pulled the compass out of this hole which looks like he used a drill to circle out a hole and punch it out.
The Inside Fiberglass on the transom is just peeling off
This is the piece of transom that I showed before I pulled the fiberglass off.
The motor. This thing is a beast and took 4 people to lift it to the stand.
I will post more pictures and update as they happen.
Under the rub rail.
