Re: Winter project,any hints suggestions
Maybe thats why someone chucked the unit into the trashcan. It's in like-new condition. I played with it enough to see that it worked but have never tried to actually cool anything with it, could take hours...days? It definitely isnt a refrigerator. I presume if the technology were efficient it would be in the refrigerators in our homes. On the other hand, if you are tooling around for a weekend and have the alternator alternating, it may be usable. I would be concerned about any heat build up around the plug if too hot to touch. I supposed I should checkout the one I have. The power supply input is labeled 5amps at 12vdc. <br /><br />From Igloos website:<br /><br />The following usage points are recommended to achieve optimal Igloo Thermoelectric cooler performance:<br /><br />- Store the cooler in surroundings at normal room temperatures for at least 12 hours prior to use.<br /><br />- Plug in the Igloo Thermoelectric cooler and let it cool down for approximately three hours prior to loading contents.<br /><br />- Items placed in the cooler should be pre-chilled in a refrigerator or freezer.<br /><br />- During use, the cooler should be kept in a shaded area when possible. As with any cooler use, Igloo Thermoelectric coolers work best when placed away from direct sunlight. Because the Igloo Thermoelectric cooler needs ventilation for proper use, never operate any Igloo Thermoelectric cooler in a trunk or any enclosed area.<br /><br />- The cooler lid should be closed promptly after opening and remain closed when items are not being placed in, or being taken from, the unit.<br /><br />Most Igloo Thermoelectric coolers are designed to cool up to 44 degrees F below ambient temperature (the temperature of the unit surroundings, as in room temperature, car temperature, or outdoor temperature). The recommended operating temperature for Igloo Thermoelectric coolers is between 68 and 80 degrees F.
