LuvBoating
- Joined
- Mar 16, 2009
- 718
I have been told that "winterizing" is not needed in Florida. We haven't "winterized" our 1992 20' Cuddy Cabin since we bought it here in 2009 and it seems to have been fine each Spring. We done the "winterization" thing to our 1989 Bowrider when we lived south of Denver, CO, but their winters there are TRUE winters!
What we do is:
Fill the gas tank and add ethenol treatment.
Go over to the boat at least once a month, put the hose on it, start it up and let it run a couple of minutes. I was told that that is better than simply letting the boat sit during the cold times and not running it at all. But, I was also told that, when I put the hose on the drive and start it, I'm putting water into the engine that won't come out.........and that isn't necessarily good........taking the chance of that water freezing in the block. As already stated, we haven't had a problem "winter starting" it since we bought it in '09, but I wanted some opinions.
If you live in Florida, do you or don't you "winterize" your boat? If not, do you do anything to it during those cold times?
What we do is:
