Winterize 350 Mag
vans
First time with this engine, Merc with 3 point drain system
Problem-It's to easy, I feel I must have missed something, I'm used to pulling plugs from block, pulling hoses etc.
I removed the four blue plugs like manual told me to do, had plenty of water come out, then reinstalled plugs, dumped a gallon of rv antifreeze down tstat housing, removed plugs again to check color-which was pink, reinstalled plugs and dumped 2 more gallons in it, as added protection
Lower unit-Bravo 3, used an old pump up garden sprayer to pump the 3+ quarts of lube in it. Worked like a champ!, my plastic screw in fitting and hose off my quart pump adapted easily to my sprayer.
Ayuh,... I build 1 of those a few years ago, with a 1 gallon metal sprayer, 'n an ole metal fittin' off an ole thrown away qt. bottle pump,.....
If I were to have 1 of the Merc drain Systems,.....
I'd pull it ALL Off, 'n use plain ole 1/4 pipe brass pipe plugs,....
With yer "System", ya can't poke, 'n prod the Crud outa the block drains,.....
'n of course,.... I store Dry,..... Air just Don't Freeze,.....
achris
More fish than mountain goat
In 30+ years of boating and mechanicing, including a stint as a Merc dealership owner, the only engines I ever put antifreeze in were 470s....
Leave the block empty and you have no problems.
thumpar
I agree with the above about pulling the drain system and putting in regular plugs. I also agree about antifreeze. If you want to use it drain water, put it in AF and drain again. It is kind of a waste of money though. I am on my 9th year owning a boat and never used it.
Starcraft5834
I drained mine yesterday..changed fluids.. antifreeze is a waste of money..the only extra protection it offers is the misconception...that folks actually think it protects the engine.. air dont freeze..just drain it
HT32BSX115
That 3 point drain system works really good on a brand new engine the first time you use it!
But once the boat has been used a season or two, the debris and rust flakes will start collecting and unless you completely remove the 3-point plumbing and expose the drains directly so you can poke wire, thin screwdriver, nail etc in the holes, there no way to ensure that all the water is completely drained out of the block.
THEN, adding anti-freeze to the block may not completely mix with the remaining water that didn't drain out of the block.........
T H E N ..........around next APRIL/MAY you're coming on here asking all of us why you have water in your oil!
Just saying.............
Good luck!
Rick
vans
I knew it couldn't be EASY, I know exactly what your speaking of regarding debris in drains, I seen it in other boats I've winterized.
_vn_
i am also little skeptic about flawlessness of drain system on my Mercruiser 6.2mpi (garbage from lake).
pulling my engine is a 12 hour job last time it happened, i think extra 30 min of my time and few gallons of RV antifreeze won't kill me - just to have a better sleep ;)
i did it last year on my vp175aq by unscrewing raw water intake hose from engine and plugging it into container with antifreeze - worked like a charm, read that doing it with muffs would be worse due to gravity. planning to do same for old boat and newer 6.2mpi engine
last winter temps in upper VT dipped all the way almost to 0F
