Winterize a 2-stroke that is used every month or so in winter?
Osprey
1995 Yamaha 175 - Used every month to six weeks or so during the winter. Stored outside with cover. Should it be fogged between uses? Any other winter maintanence required?
BugEyes
Re: Winterize a 2-stroke that is used every month or so in winter?
San Diego winter, does that exist?<br />If you use it seldom, add a little extra two stroke oil in the gas and the interiors will be fatter for storage. A barrel run on freshwater before each 1 month storage would lessen chrystalized salt in the cooling channels and thereby corrosion.
