Winterize OMC King Cobra
hurwitzer
I have a 1990 Donzi Blackwidow with the original 454 King Cobra Stern Drive. I do some work myself and am fairly skilled with a wrench. Have never winerized an I/O myself before, but lots of work on Inboards and Outboards. I know I need to fog the engine, change the oil, run environmentally safe antifreeze through it, change the gearcase oil, pull the drive off, store it, and grease the gimball bearing. Am I leaving anything out and could someone give me a little more exact description of what needs to be done and how to do it? I don’t want to find out in the spring that my gimball bearing has seized or the bellows are ruined because I left something out. I'm having trouble removing the gear lube filler plug and not sure where to drain it from. Thanks for the advice.<br /> -Aaron
Re: Winterize OMC King Cobra
Go to the Top of This page,+ Click on the red Seach button....<br />Then type in "Winterize"........<br />If you have any more questions after you've read all that, We'll be here............<br /><br />BTW, Welcome to the iboat forums.......
