Engine winterized 20 months ago then wouldn't spark. Found and fixed loose flywheel magnets - still no spark. Got the diagnostic procedure and relevant meters and wroekd through the system. The stator is reading Open (5MegOhms) Blue to Red so that explains no spark.<br /><br />I've two questions on this for you experts and I hope you can help. Can a stator die like this while sitting unused and does it mean the Switchbox is maybe OK or the casue of the dead stator. All other values on the stator resistance check out OK, red to ground and the two yellow leads, etc.<br /><br />I can't see the loose magnets killin the stator while cranking as tehre was no physical damage.<br /><br />The stator has black molding - does this ID it as teh old unreliable 'black' stator or how can I tell the better red stator?<br /><br />Is tehre any way to test the switch box without a good stator sending juice into it- I can access good test gear? If not can a new stator get killed by a switchbox?<br /><br />Finally any recommendations for where to pick up good used stators and maybe switchboxes, even better if you could suggest people who'd ship to Ireland but I'll find a way round that if neccessary.<br /><br />Finally I can't find the serial number on this engine and I thought I knew where to look on the transom mounts. The only number I can find is on a bit of foil on the T+T pump. Could that be it?<br /><br />Many thanks.
