I already got great info from the FAQ on winterizing, still have a question. I know I need to stabilize the fuel and change the lower unit oil. As far as fogging the motor goes, I have 3 questions:
- I'm not able to get the motor back in the lake before putting it away. Is it just as good to spray the fogging oil into the spark plug holes instead of running the motor and spraying it into the intakes?
- if it's not as good, then is it ok to fog it while the motor is on muffs? Does it matter is the motor is heated up completely before it's fogged?
- this motor is new to me so I'm a bit nervous about using muffs on it...can someone confirm exactly where the water intake is on this motor and where to put the muffs?
thanks very much!
Marc
thanks very much!
Marc
