First time winterizing this one, just wanted to point something out and make sure I did everything right.
Opened hand screw (1) until water ran out. Poked drain just to be sure. Then removed hoses 3,4, 5, and both 6s. Poured AF into 3 until it ran full pink out of drain. (Was watered down at first). Then closed hand screw(1) and kept filling until it stopped / started coming out of other hoses. Did the same to 4 and 5 until I saw AF coming out of (6s) at the manifolds. Then clamped them both back on. Topped off each hose as I clamped them back on.
Then for the heck of it, I opened the top manual drain on the thermostat (2) I was surprised to see clear water coming out. Squeezed the hoses to figure out which one was supplying it (I forgot which one). Unclammped that one and filled again until AF came out #2 drain. I was really surprised how much water was trapped somewhere in there. I did a lot of research on this system and nothing mentioned that.
I was unable to see if I had flow out of the manifolds and out of the drive. So I'm going back today to check. Which hose should I fill to get AF into manifolds and out drive?
Anything else I missed? Thank you!
