Winterizing 351 Windsor
I am winterizing this 1989 Bayliner with a 351 Windsor. To the best of my knowledge I think there is four drain plugs on this engine. There are two on the front of the exhaust manifolds underneath. And there is one on the lower starboard Front and one on the port back side. I just want to make sure I have everything covered because reading online some people say there are five or six drain plugs. Thanks for any help
Ayuh,.... I think ya found the drain plugs,.... did ya probe the holes to knock the crud outa the way, so the water all drained,..??
Also, pull the Big hose off the circulatin' water pump, it hides 'bout another quart of water,...
'n if ya got P/S, drain it's cooler,..
