Horigan
- Joined
- Jun 12, 2016
- 691
I have recently acquired 1995 Chris Craft 21 Concept with a Ford 5.0 EFI engine (50FAPHUE) with a closed water system. I'm not sure if the closed system was stock or added later. The provided OMC pamphlet manual talks about removing drain plugs on the block and exhaust manifold on both sides of the engine to winterize it. When I look at my OMC shop manuals, as well as the Seloc and Clymer manuals, they don't go in to specifics on how to winterize a closed system. The Boatinfo online OMC manual does show water flow diagrams for the closed system and it indicates the raw water does not flow through the block, but it does flow through the oil coolers and exhaust manifolds.
Can anyone confirm that I only need to open the drains in the exhaust manifolds, as well as drain the hoses to the raw water pump and blow the coolers out, to winterize this closed system?
Thanks in advance.
Rich
Thanks in advance.
Rich
