Winterizing question on force 89' 85hp
birdgod
Hi, first of all I would like to thanks all the fine person on this forums , as a newbie, I counld never have put the boat in the water and got it running. Thanks again.
I now have question about winterizing.
I was winterizing this morning, start off getting the motor running on idle and spay the fogging oil in the intake until the engine shut down. Then I remove the spark plus and spay the fogging oil in the plugs hole for 10 sec each according to the manuel. After that I then the flywheel by hand a few times and let the fogging oil goes evenly. I then clean the spark plug and replace them.
Now here is some question I have;
1) the spark plugs have some black and fine stuff on it. Just a little because the plus are new and I only ran it once since I change it. Does it mean my crab needs cleaning?
2) after I spay foggin oil in the plug holes and turn the flywheel. Some of the fogging oil start to come out of the exhaust, along there is quite a lot of the black fine "sand" in it. It is normal? should the fogging oil come out of the exhaust? and since there is this black substance, does it means this my system is very dirty? how do i clean it? p/s: the engine run fine with top speed 30mph.
3) I search on the forums about decarb the engine. I know the way , but what spay do I use to decard the engine? carb cleaner? fogging oil? if you could let me know what is the name of the spay and where i can get it, it would be a big help.
4) I would like to put libricant on the joins in the engine and the propeller and the trailer wheel. are they the same greese? can you tell me what is the name of the lubricant to buy? Thanks.
