I have 2 questions really.
One is the power steering cooler really needed, I had one boat with it, one without, same make, same year, same engine -4.3 (one is early 96, one is late 96 - so they have different heads)? It is a pain to get the hoses off to drain the heat exchanger.
Two - I went to a full closed system due to keep corrosion down. I only use the boat 1 to 2 weeks a year and in salt water - good full flush after - but interior engine rust was just out of hand. So back to the question
My heat exchanger outlets are slightly above the riser inlets, should I add a little antifreeze to the risers - or are they fully self draining?
Bow is slightly down, any chance of antifreeze going into the engine if I do add it? If so I can raise it after I take the drive off for winter.
