Likesspace
- Joined
- Aug 25, 2016
- 17
Hi Guys,
I have a Mercury, (re-branded Yamaha), 50 HP, 4 stroke, 4 cylinder outboard that is either a 1999 or 2000 model year.
After reading the manual concerning the winterizing procedure I have a question.
It says that I am supposed to pull the spark plugs and put a "small amount" of motor oil in each cylinder. I'm then supposed to rotate the timing belt to distribute the oil throughout the cylinders.
My question is: What is a small amount? Are we talking a teaspoon or less or more?
Also when I go to start the motor next spring do I need to pull the plugs again and rotate the motor to blow any excess oil out of the cylinder?
This is my first year winterizing the motor so I'm sort of at a loss. Any help you can give will be appreciated.
Thanks in advance,
Dave
Thanks in advance,
Dave
