Re: Winterizing Tips
Where does the OP say anything about dents??
You should at the least change your lower unit oil with a good lower unit oil, if your engine is new make sure you use the correct oil so you don't void your warranty and get some Stabil in the gas making sure to run the engine till you are sure it has taken the treated gas ANd that si reall yall there is.
Being an OB you don't need to worry baout running anti freeze through it.
Batdaddy, I am the repair guy at Bennington, please have your marina send me some of that air that knows where a dent is in the tube, it would save me a ton of time fixxing tubes.
Sorry but the air in the tube pushes out the same on the entire tube and it is not going to push a dent out especially with only 5 psi, we check our tubes with 10 psi and it doesn't push the tubes out anywhere anf certianly won't fix a dent, not calling you a liar or anything but that isn't how it was fixxed.
I would suspect they used a dent puller and filled the holes in, that is the only way I have ever found to fix dents and have repaired alot of tubes in my 23 years.
By the way DO NOT EVER put more than 2-3 psi in a tube, check the sticky at the top of this forum before you do, we use so much air as part of our quality check, if ti can't hold that much air without damage I don't want it in the field, by the way that tube was the last one to let go.
