Winterizing
falker
Can someone please explain or direct me to a good web site explaining the best way to winterize my 115 merc (1975)<br /><br />Any help would be appreciated<br /><br />Falker
CU2NITE
Re: Winterizing
Put stabilizer in gas, run engine on ears and fog carbs, shut engine off and put a shot of fogging oil in each cylinder, change lower unit oil, charge batteries, store motor with the motor in a down position to let water run out. Put it in the shed and forget about it! Also type in winterization in the search at the top of the page and you will find lots of the same info. Good luck.<br />CU<br /><br />--------------------<br />RUNNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
