winterizing?
ambdriver
i have a 1986 bayliner cuddie and am a first year boat owner, winter is coming and our boating days are almost over, how do i winterizie my 85 horse force so i can turn the key next year and have no problems< any help would be great thanks.
Bifflefan
Re: winterizing?
Add sta-bil, fog per instructions on the can, store upright so all the water is drained out.
There are 2 different thoughts on running it out of gas or not, for me its no.
Your manual will have the winterizing needed for your engine type.
emoney
Re: winterizing?
The absolute, no-fail, best way to winterize a boat is to move to Florida.
I'm telling 'ya, it worked very well for me:D
Frank Acampora
Re: winterizing?
Back the and trailer boat into its resting spot, tilt the engine vertical so all water drains, disconnect the battery, and go inside the house to watch football. Oh yeah---Cover the boat with a heavy duty tarp supported by some sort of frame if it is to be left outside.
ambdriver
Re: winterizing?
florida huh? i wish i could! going to add sta-bill to the gas, should i run the motor out or leave some treated fuel in the carbs? im just a dumb firefighter with no clue but to put out fires.
ezmobee
Re: winterizing?
To be honest I've never done anything to winterize mine other than changing the lower unit oil just in case any water got in there during the season. Running Stabil in your last tank of gas is a sound idea.
emoney
Re: winterizing?
I think you'll find just as many people who argue for both answers to
that question. I still, after all these years, haven't figured out who's
right.
JB
Re: winterizing?
Most of the "only way to do it" work just fine.
For many years all I did was put stabil in the tank and run the carb(s) dry. All of the gurus will tell you that is a bad way to do it, but it worked for me.
jerryjerry05
Re: winterizing?
Put stabil in the gas.Run it and make sure it's in the carbs/injectors.Then fog it.Don't run it out of gas.Some do I don't.
Run it in fresh water to fog.Salt water will leave big clumps of salt.
Leave it in an upright position so it drains.Change the oil in the lower.
Unhook the batteries and put them in the garage on a piece of wood.J
