I have a 2001 Mercury 3.0 liter with an Alpha 1 Gen 2 drive. The motor is equipped with the "quick drain" hoses. Usually when I winterize, I fog the engine and then drain the water. I then remove the thermostat and fill the block with the pink antifreeze. My question is this: could I fill a large tub with the antifreeze and with the lower unit submerged run the engine until the antifreeze is circulated throughout the engine? That way I would not have to remove the thermostat. Any input would be appreciated. Thanks to all.
