Re: Winterizing
hi, you should remove all fuel from engine,carbs,bowls,filters etc,and pull off water hose at thermostat and let all water left drain out that may have not drained out it usually does when you pull motor up out of water. and if you are really redicilous like i am you can take out your plugs and spray wd-40 in cylinders and screw your plugs back in,that is how i make my engines last 2000 hours before there dead!
