Wiper Replacement - Grady White 1992
gtashie
I know, I know ANOTHER stupid question about wipers..Here's my scenario - my wiper blade flew off,leaving me with the wiper mechanism (the wide piece that has the spring loaded onto it) and a flat metal bar that is inserted into the mechanism and held tight by a small lever. The lever tightens and loosens so you can slide this flat bar up and down to adjust the blade to cover more/less of the windshield. The bar has a small nipple on the bottom that prevents it from sliding all the way out - and a hole at the top which I think is there to insert a small screw that holds the wiper blade in place.
I cant find a replacement to fit onto that flat bar. Does anybody know what I'm talking about?? Someone posted that I should pick up the ANCO 52-16, but according to the shop owner it doesnt come with anyway to attach it to the flat bar on my wiper mechanism.
Help is appreciated - as always
dontask
Re: Wiper Replacement - Grady White 1992
Did you try contacting Pompano Beach Marine Center (PBMC) in Pompano Fla? They are a large Grady White dealership and if they don't have one new they may have used. I've used them many times in the past.
