whistler66
- Joined
- Nov 27, 2008
- 52
My trailer rail is too think for the typical wire clips used to hold the trailer wire that runs along the rails. I can get them started on the rail but when I tap them to snug them up to allow the little grips to contact the rails and hold them in place the clips are then stretched out too wide to hold. I have some of the wire looms that I can use but that requires drilling at each spot along the frame. Rather not do that if there's another solution. I don't know whether the glue on type holders for wire ties will stay on with the constant in an out of water. I can't be the only one with this problem what are you guys going?
