acdc96
- Joined
- Apr 23, 2013
- 412
On both my trailer and boat the wiring in them are mostly copper. I'm fed up with connectors cause of all the corrosion that occurs, so I'm taking out most of the connectors and just soldering them together ( Except for ring, spade, & plugs connectors). On some of them when i strip the wire their is this black substance or something on the copper wire. it's dry and very fine. this makes soldering very difficult because the solder will not go onto the wires. I put flux on the wires and soldering gun to clean them, i use solder with flux in it, and the soldering gun is hot enough to melt and apply the solder.
I'm really at a loss here. i don't know if it's corrosion cause corrosion is usually a greenish/blueish color.
I don't want to replace the wiring its to expensive.
any ideas on what this could be?
and how to clean or solve this problem??
thanks in advance.
thanks in advance.
