Re: Wire cut 175 merc
So, just ground that wire off while the key is in on position and see what happens?
Exactly!
If you have a circuit tester, you can use it to see if the cut tan/blue wire has current, first. The tan/blue wires on my engine are current fed, with the key in 'run'. If you don't have the circuit test light...then simply ground the wire to the engine.
I would also test ground the connected one you mentioned...if the buzzer works, when grounded, then you have some degree of protection. It could be that the cut one was going to a faulty temp switch...and the owner found it easier to simply disable that particular temp switch. Not my way to correct an issue...!
Mercury temperature switches, for the audible warning system, are sold on eBay. The come in two color codes...red, and black. My Mercruiser 3.0L uses the red one, and I have one coming. The black one triggers at a higher temperature, and seems to be used on the 6 and 8 cyl I/Os. You should look to the connected tan/blue wire, and see what it is connected to.
