The boat has been off the water for a while, one thing after another. Stearn drive gears, Bellows tear (major intake of water in boat, ie without foam would have sunk), exhaust crack leak, impeller replacement etc...
After last job of replacing impeller she starts right up. I'm running her on muffs. I let it run for maybe a minute on idle then try to shift into gear. Stall. May have been a bit slow on idle? At any rate I get my timing gun setup to double check timing and try to start...turns over but no start. How odd it had just started easily.
OK got fuel and air lets look at spark...nope no spark. Go through testing and find I get no power on the point/condenser side of coil. Keep going through troubleshooting guide. remove the wires from output side of coil. OK, now have power. Replace wire going to points/condenser OK, now get alternating power like I should. Add grey wire and no more power.
So I look at diagram included as attachment and see it says sender to tach. So this should just be how the tach is measuring revs right? Connection should not be needed to start boat right?
Bonus question. The fact it stalled putting it into gear, does that point to anything other than maybe engine speed was too low?
